GPU help
10 Aug 2011
Hello, Jusst bought a new build
the spec is as follows
Intel Core i7-2700K 3.50GHz (Sandybridge) Socket LGA1155 Processor - Retail £239.99
(£199.99) £239.99
(£199.99)
EVGA GeForce GTX 460 Superclocked FTW 1024MB GDDR5 PCI-Express Graphics Card (01G-P3-1363-KR) £124.99
(£104.16) £124.99
(£104.16)
Samsung S24B300HL 23.6" Widescreen LED Monitor - Black **BTS £20 CASHBACK** £122.39
(£101.99) £122.39
(£101.99)
Fractal Design Define R4 Midi Tower Case - Black Pearl £89.99
(£74.99) £89.99
(£74.99)
Samsung 128GB SSD 830 Desktop Series SATA 6Gb/s KIT with Norton Ghost - (MZ-7PC128D/EU) £89.99
(£74.99) £89.99
(£74.99)
Gigabyte Z77-D3H Intel Z77 (Socket 1155) DDR3 Motherboard £84.98
(£70.82) £84.98
(£70.82)
Microsoft Windows 7 Home Premium SP1 64-Bit - OEM (GFC-02050) £83.99
(£69.99) £83.99
(£69.99)
Seagate Barracuda 7200RPM 1TB SATA 6Gb/s 64MB Cache - OEM (ST1000DM003) £64.99
(£54.16) £64.99
(£54.16)
TeamGroup Elite 16GB (2x8GB) DDR3 PC3-12800C11 1600MHz Dual Channel Kit (TED316G1600HC11DC) £59.99
(£49.99) £59.99
(£49.99)
Cooler Master Silent Pro Modular 500W '80 Plus Bronze' Power Supply £54.98
(£45.82) £54.98
(£45.82)
Cooler Master Hyper TX3 Evo CPU Cooler (Socket Intel Socket LGA1366/1156/1155/775 / AMD Socket FM1/AM3+/AM3/AM2) £19.99
(£16.66) £19.99
(£16.66)
Sony Optiarc AD-7280S 24x DVD±RW SATA ReWriter (Black) - OEM £14.99
(£12.49) £14.99
The problem seems to be that the GPU doesn't fit into the mobo, due to the case, support bracket getting in the way, it clicks in but doesn't look 100% into the slot (which it does fit)
Any work around to this? I can upload pics if needed.
The computer its self runs fine (off the Mobo integrated gpu)
Does this sound like it's the problem i think, or is it a bad gpu? :confused::confused::confused:
