Gpu low usage, stuttering.
10 May 2009
Hi,
my boys pc is stuttering in fortnite, the fps are up and down.
ive checked the gpu usage and it's shooting up and down .
Anyone got any ideas why gpu is not running properly.
Thanks.
I've seen similar while trying to play on a TV over HDMI. Nvidia control panel/manage 3d settings and set preferred refresh rate to maximum available. I suspect the setting is only visible over hdmi, can't remember it being there on a monitor with display port. Symptoms were as you described though, frame rate and gpu usage all over the place.
