help me! help me!
i recently got another gtx 275
so ive got 2, i'm sure you know what they look like
well, ive got them working in sli, not really seeing much fps difference but it says its all working in the game with the nvidia indicator
but when i play say team fortress 2 for about an hour it will freeze up and i try ctrl + alt + del and nothing, so...
I open up my case and check it, the top graphics card under neith it is pretty hot compared to the bottom one, but then! I feel the heat sink on my mother board and OMG!
it so hot it hurt my thinger
this must be the problem then...
my case, i have a good cpu fan, and 2 normal fans umm you know the normal size.. 1 on the front sucking in and blowing in to the case, and one at the back above the graphics cards blowing out of the case.
i have a spare smaller fan, and a fan off an old geforce 6000 series, it is pretty small with a heat transfer and fan small and thin
so the main verdict
how can i prevent this over heating, and why is my motherboards heat transfer thing so hot, (it is between the graphics cards).
I would be really thankful if some of you actually read this. Thanks
ask any questions, also the mother board is from about 2007 and is made by asus, (M2N-E SLI) its even designed for sli...
also the cards arnt over clocked and my room is cool
so the main verdict
