gpu/monitor question
Permabanned
18 Apr 2006
14 miles from OcUK
Im going to get a belinea 22" widescreen i think, just wondering if my 7950gt will do the job at 1680x1050
thanks
'do the job'? Could you be a bit more specific?
Windows - Should be fine lol :D
Doom 3 - Fine
Oblivion - Probably not.
Everything else somewhere in between...
cheers for the reply mate, sorry i ment will it handle the new games on high resolution
TBH i kind of expected to be told it would struggle with high res as it wont do high settings on nfs carbon or bf2142 on my 17"crt.
Say i was to get another 7950gt and go sli how much difference would that make and would it run highest settings on a 22"widescreen or should i just sell my 7950 and get a 8800gtx?
thanks
stinka
With the rig you have mate i'd sell the 7950 and go for an 8800gts. I picked one up for a very reasonable price, which can be done with a little searching, and at 1680x1050 it rocks!!! MY NEC has never looked so good and it beats the pants off the Gainward 7900GT 512 Golden Sample SLi setup i had...
No worries
For the games it runs well, it will run quicker. But Something like Oblivion (and FEAR I believe) the way the game is designed needs a different graphics approach than an nvidia 7 series. I would upgrade to an 8800 GTX/GTS if you can afford it.
