GPU monitoring software
16 Jan 2021
Hi I have a new 7900xt and want to see what my average and 1% lows are but i can't see it in the adrenalin software, can anyone recommend some software?
@Andye1985 - it's also in the Adrenaline software:
Go to the performance tab and then metrics, and expand the FPS panel with the 'additional metrics' button. (it's labelled as 99th % FPS)
You can also enable the in game overlay which can show this by pressing ctrl-shift-O
The panel on the right (tracking/overlay) allows you to configure what you want to display
