GPU of MM?
  • Thread starter Thread starter IC3
  • Start date Start date
IC3
IC3
3 Dec 2011
Hi, yestarday finally reached 1k posts.
Had a look at MM, and there are some great prices going on there. Was thinking of looking for a gpu 7850,7870,7950 or gtx 660ti,670 with warranty.
Good idea or bad?
Depends on the seller but generally good :)
I think you should buy a 7970 lightning :o
Let me guess. From you? :D
Don't want to spend that much on a GPU. 230 would be the max, I can spend.
But I might think about it, why are you selling your 7970 anyway? Because of the bad experience with MSI?
Most people sell due to upgrade, though recently there a lot of people downgrading or switch between NVIDIA and AMD. Great place to grab a bargain.
No just fancy a mess around with something less expensive so going reference.
Actually moving to msi oc 7970's :)
Can't wait to get my post count high enough so I can access this mystical market you speak of!
I would say you would be fine buying from the mm it's all users on here that have to have a certain dedication to get the posts so not just random guy who has made a account and selling things
*off
MM is fine but make sure you read the person's TRUST status... you may find a bad apple!
True, though thankfully its rare that it happens. Ive had well over 100 succesful deals in MM, (trust only shows 101, as people sometimes forget to leave feedback). Ive picked up some great kit including gpu's over the years, all at good prices.
Thanks for advice.
7950 or 670 is the max.
If I got one of the cards above for less than 200 I would be very happy!
Got a offer for gtx 670 from evga 210 pounds with 3 year warranty. 7 positive comments.
What you guys think?
