GPU + Onboard?
29 Aug 2010
United Kingdom
Hi guys,
So I have been trying to find a solution for getting all three of my monitors enabled on my Graphics card, But have found that the ATI 6850 only supports two monitors between the Two DVI + 1 HDMI due to the fact that they use the same bandwidth, and I have no desire to spend stupid amounts of money to get an active display port adapter to work, So I looked on the back of my motherboard and can see I have Display-port and HDMI out, I have plugged a HDMI cable in from my third monitor to the board (32inch TV) but cannot get a signal on it and it does not display in windows.
Is it possible to have another monitor/TV connected via the motherboard or not?if it is how do I go about doing it? is there something in the bios I need to select?
Thanks!
rob
go onto your bios, and you have to enable the igpu
Advanced Mode --> Advanced tab page--> System Agent Configuration sub-page --> Initiate iGPU setting
Have you installed the onboard graphics drivers and also the lucid virtu drivers on you motherboard, in that order?
Not sure how I go about doing that? can you download them direct from the Intel website?
EDIT: Don't worry, Popped up in windows update when I enabled it, Downloaded the lucid drivers and bam, awesome stuff.
thanks people!
