GPU or not?
19 Jan 2005
Romford, Essex
I have a small form factor Gigabyte M/B and an i3 CPU. I only use the PC for office work and browsing. But I find certain sites that are full of external links and advertising pop-ups take a long time to populate.
Apart from blocking popups is there a way to accelerate population or is the solution a dedicated GPU. If the GPU is the solution, could you please recommend me a cheapish one please.
I have Gigabyte GA-B85M-HD3, i3, 8mb Ram, 128 SSD and W7 64 bit.
I'd appreciate your help, thanks.
I presume you mean 8 GB!
You can easily tell where the bottleneck lies by bringing up Task Manager. If your CPU is running at 100%, then you need a CPU upgrade. If one of the CPU cores is running at 100% and the other cores are near idle then you should try a different browser. Task Manager will also tell you if you need more RAM. And so on.
There's one key factor you haven't mentioned: your internet bandwidth. Most likely the cause is your internet bandwidth with all those advertising sites taking a long time to respond, and an adblocker will sort that out very quickly.
The REAL question is what websites are you visiting that are so full of pop-ups? ;)
Although I'd don't frequent these sites. I occasionally am tempted to see what people have aged like. These links appear at the bottom of more bona-fide sites and when you visit them, the pages take forever to populate.
http://okceleb.com/incredible-celebrity-transformations/3/ for example
My BB speed is 200Mb on VirginMedia.
Why not just use an adblocker? Although I just checked with that site, and even with the adblocker off it still loaded pretty decent for me on a 16mb connection. Have you done a speed test to check if the Virgin connection is not being congested? Maybe change the DNS servers to Google?
My BB is running 220mb. Most sites populate nearly instantly. It's only the ones in my example and Google maps and TomTom map for other examples.
Speedtest.net shows that my ping is 19ms and speed is 220mbs download, no mention of bandwidth.
Epic broadband just pwned Quartz ;)
A graphics card in this instance should have no impact on the speed of popups e.t.c to load, is almost entirely a processor load.
Please provide feedback as requested before, are all cores loaded, or just one?
Epic broadband just pwned Quartz - what do you mean?
I used a performance monitor and when loading the graphic/ad intense site. It showed CPU usage at 100% and at one point each of the 4 cores showing 100% too.
Right. You are CPU-bound. Get yourself an ad blocker to knock those ads on the head. A Flash blocker would be a good idea too.
