So, having issues with a new build, constant crashes, failing to boot etc.
MSI Gaming Pro Max (or B450 A pro max for testing)
AMD 2600X (or 1500X for testing)
16GB (2x8 Corsair )
5x570 8gb Nitro
Seasonic 500W psu
Couldn't get it to run very well at all and had a lot of trouble getting it to post and boot.
After much wailing and gnashing of teeth I bought another chip. Same result
Bought another mobo, same result, with either chip.
In desperation, I pulled the GPU and stuck in one from the 1970s, some old radeon thing I found gathering dust in the back of a very dark cupboard.
However, now it works just fine. Posts, boots, reboots, loads win 10 all just fine, just how you would expect.
So now I'm wondering which is the cause. Gut says GPU, but the nagging doubt is that it has an 8way and a 6way power input on the GPU and I'm using the same lead from my PSU to do both. (8way with a 6way daisy chained off it. I've no other option.)
So, OC folks, anyone had anything similar. The only other thing I could try now is to power the GPU from a completely separate PSU to test that theory but I'm not sure if that would really give me the answer.
16GB (2x8 Corsair )
5x570 8gb Nitro
Seasonic 500W psu
