Hello all,
I've searched around and cannot find anything, so thought I’d ask you guys here.
I'm looking for an application to monitor and display GPU temp, memory usage and FPS within game, (On-Screen Display) would be nice to see CPU Usage+Temps also but isn’t necessary. I'm currently using EVGA Precision for this, but because I’m running something called ENBSeries mod for GTAIV that using d3d9 when running EVGA Precision it cannot load and causing game to crash at load up. I think its because EVGA Precision is already using d3d9 and so the ENBSeries cannot function. I've also tried loading up the game then after running EVGA Precision but it just causing the game to crash because I guess d3d9 is already being used?
So to re-cap, I'm in need of an application that monitors and displays GPU information in-game(On-Screen Display) that doesn’t use d3d9(Not sure if this is possible though..
Hopefully you guys will know a certain application that can do this.
Thanks for your time!
)Hopefully you guys will know a certain application that can do this.
