GPU Overclocking help
1 Nov 2013
Hey all,
I've just ran an ASIC test on my used 980 Ti i bought today.
Its a pretty good overclocker. +235 Core & +525 Mem. +110% Power.
I'd like for anyone with some experience to help me add some extra voltage to this card so i get get the max overclock possible.
Anyone up for the job?
Be happy with what you have and don't kill it. ;)
More volts = less life span.
What do you want, it to go like the clappers for 12 months and die or take it easy and have a resale value? :confused:
I want to reach the max stable overclock possible , can you help?
You have a good card don't kill it with that ASIC of just under 95%.
I would call it quits unless you want to go under water.
Even then I would be apprehensive, I have a good 780ti and it will clock faster but I don't see the point as you will kill the card faster.
My cpu can do nearly 5ghz but I am not prepared to kill it for a few extra Ghz.
The will be members here that can help, but don't push it too far as you are already high with a 110% voltage.
