GPU Overclocking software for Vista 64-Bit?
Hi as far as I am aware and I check the forums etc often no software overclocking works in Vista x64 as yet, but I`m sure if it is someone will correct me, I have to flash my bios to get the clocks I run. :)
Hope this is of some help.
00NukE
tis working, at least a bit, on my 64bit ultimate. need to disable driver signing apparently for it to work. mine came up with the 64bit driver being unsigned warning, however i didn't have to boot into no driver signing mode(f8 as you boot then you can choose no driver signing), it just worked straight off. but i've messed with some command line stuff to force no driver signing. i wasn't sure if it worked as i still got that unsigned warning but there ya go.
