gpu power connections?
12 Feb 2004
Chesterfield
after messing about with cables in my rig last night I noticed an extra Molex connector on the board just below the cpu which I've previously ignored. After checking the manual, it suggests that this connector is to power the PCIE graphics card. Obviously, the gpu has it's own connector for power. Does anyone know whether both should be connected?
If i remember rightly in my manual it said only use if you are using SLI, i dont have mine in and only running 1 card and its fine
