Hi OC - was wondering if anyone could help or offer some advice as I'm pretty stuck.
I sold my old graphics card, a 1060 Strix, on eBay recently. The card was in full working order and I never experienced any problems. It was sent securely in its original box with new packaging including airtight bag and bubblewrap.
After 5 days of receiving the item, the buyer requested a refund/return, stating the following;
At first I thought the guy was just trying his luck, but after exchanging further messages I think he is legit and generally having problems. Further message from him;
For reference, this is my PC specs when I was running it and I had zero problems;
i5 6500 3.2ghz
Asus Prime B250Plus ATX
Corsair CXN 650w
Kingston Fury Ddr4 2400mhz 4gb X 2
I had the GPU connected via DP.
I'm at a bit of a loss as to what the problem is, as I really don't think its the card and more of a Software/Settings issue he has. I'm not the most technical minded so its starting to go over my head now, so if anyone has experienced this before or may have a solution and can help that would be great!
Thanks in advance!
Reason for return
Doesn't work or is defective
Comments
Hey there, I ve been having a ton of problems with this strix card. I ve done a ton of testing and it only seems to work under certain conditions. It works with my i7-z370 combo, it works in a pci-e x4 slot and it works with a ryzen 2400g with in-built graphics. Any other circumstances and I get no display at all. I ve tested 4 boards, 4 cpus, 2 ram kits, 3 psus. My hunch is that it works fine with an igpu in the build but I can t use it for it s intended purpose and I d like to return it.
I was inclined to believe it was the build (r5-b350 combo) that had the problem to begin with. The last thing you want is the gpu to be the problem When i seen there was no display in the first place i ran through all the common troubleshooting steps and then decided to check it in my main rig (i7-z370 combo). It displayed fine in that build so i tried a 1050ti and a 1080ti in the r5 build to see if it was the graphics port that was faulty and they both worked so it wasnt the motherboard. I ordered and tried another psu to no avail and at that point i tried with different cpus, different motherboards different ram sets, all of the other parts working with each other apart from the 1060. BUT i knew it was working in my i7 build so it’s messing with my head. It also worked with a ryzen apu so like i say it would appear it works in tandem with a cpu with on board graphics since the i7 also has it’s own igpu. Would you mind if i ask what your pc specs were when using this card? I believe you when you tell me it was working when you sent it out (and it works under certain conditions for me too) but i’m thinking perhaps your pc specs fell under the conditions needed for it to work just out of luck. Also it displayed on a pcie 2.0 x4 expansion slot on a b350 board but not the pci-e 3.0 x16 graphics slot which makes it usable but not at full performance which i could live with personally but since i’m selling this build it has to be 100%.
i5 6500 3.2ghz
Corsair CXN 650w
Thanks in advance!
