GPU Problem???
25 Oct 2014
Milton Keynes
Hey guys
I've been getting screen flicker for the last probably week or more. It's a quick flicker of about a second then it's ok, sometimes it'll flicker a couple times. I've tried changing the cables, running different res and refresh and also different screens and it still does it. I'm assuming it is either the drivers or the GPU itself, it's a Sapphire 390X bought from here about a couple months or so ago. Also running a single 1920x1200 screen and a 43" 1920x1080 auxiliary screen above.
So any ideas???
Think it's due to multi-monitor clocks.
Does it do it with just one monitor connected?
I think it could have been. Last night i disabled the second screen and the flickering has disappeared. I think i'll have to source another screen to go above and do away with the 43".
Thanks for the help man :)
There's a get around if you manually apply full speed memory clocks for your 2d clocks.
Using afterburner or similar apps, but the card will idle with high power consumption and heat
Have a google on it.
