with the games i play i expect the 3090 to last me 5 yearsWhat's the point in buying a PSU for the 3090 when your next GPU upgrade in a few years could need even more power?
well its lasted me well over 5 years so its done ok.You made that mistake when you bought the 650w.
Obviously, a 750 or 850 will do you. But if you wanted a bit more in reserve for later...
if you're going to spend that much, you might as well pick up an ATX 3.0/PCIE5 PSU so you have the option of carrying that on to your new build in the futureall pick up a RM850w
