GPU question
21 Oct 2012
do they all require a min of 2gb ram(ones ive seen appears to) and how do you know the psu requirements as some boxes/online specs ive looked at dont specify??
my computer has 2gb of ram and at some point going up upgrade the lot for newer better tech and double the ram as a min, so its not really a problem, just when i look at the specs i start questioning their compatibility..
okay an example, my computer is a SFF and has a 220w psu, it currently has a 8500GT and i was advised a HD 6450(i want hdmi port) would be the next in line for the given setup, but looking at the box in store it doesnt say, only GPU's that seem to get a psu mention are the higher ends you guys use for gaming.
It is wise to get a card with 2GB, all newer cards come with 2GB standard. And you will need a better PSU to run those cards, at least 450-500w.
