Gpu recommendation under £130
22 Nov 2010
I’m a bit out the loop in terms of what’s good or not at the moment.
Girlfriend is looking to upgrade the gpu in her son’s pc from a 970 to something a bit more modern.
What would be the best gpu that we should be looking for around the £130 mark? Probably 2nd hand to get the more bang for the buck.
Around that price you are probably looking at a 1080TI or 2070 Super 2nd hand.
I've gone from a 970 to a 1080 in my Daughters PC, and it's made a big difference in Roblox. I'd probably go for the 2070 Super just for the newer generation.
Maybe someone will be along with a Radeon alternative.
Nothing brand new. Second hand you could pick up a 1080ti as they have recently been going for that in the MM and a RX7600 went for £110 recently. £20-30 more and you may get a RX6700/RTX 3060ti.
Ahh perfect cheers. Yeah Roblox is a big contender for what is played. Albeit he’s started getting into games like red dead redemption and I think black ops 7 might be next on his list.
I have been suprised about how well red dead is running in the 970 but know an upgrade is needed.
Ooh nice. I’ve got a 3060ti in my own machine. I didn’t realise they were quite so cheap.
I’ve seen some of the intel gpus going new for 150-200 so wondered if they’d contend.
Depending on how strict your £130 budget is, and what spec PC it's going in (i.e. it needs to be able to enable ReBAR/SAM) then the Intel B570 isn't a bad option - it gets you a brand new card with 10GB VRAM
My basket at OcUK:
Total: £173.99 (includes delivery: £3.99)​
1080/1080Ti whilst still relatively powerful is positively ancient at this point - but the below gives a relative idea of how older cards stack up against newer options
My basket at OcUK:
Very helpful thankyou. Will have a look through that later.
