Hi all, got a hopefully minor issue with my case: the two holes to fasten down the GPU are stripped. Not so badly that the screws just full out, but they don't provide a good amount of clamping force and the GPU can slide around. It's a long card, too, and I don't like the way it can flop around even it's screwed down properly, and now it's even worse!
Can anyone recommend a way to secure it nice and safely? I don't want to just glue the things, obviously, and I don't have the wherewithal to, for example, cut new threads in a larger size.
Cheers
Cheers
) On the other hand, a #8 is only .6mm wider than a #6 so maybe it'd go in. If anyone has any experience that'd be welcome, otherwise I'll just go and buy some. I imagine I'll spend a lot less than £2 anyway, it's more about not having to buy everything to save a trip and filling my house up with screws I won't ever use
