Hi guys and girls,
Hope your Christmas and New Years was good!
I'm upgrading a fairly old PC and not 100% sure what route to go with the GPU. Staying with AM4 for now.
Old build,
Case: Mattrexx deepcool 30
mobo: asrock b450m pro4
CPU: AMD ryzen 5 3600
RAM: 2 x 8 gb 3200 cl18 ddr4
PSU: CX450M
GPU: GTX 1060 6GB
Storage: Sabrent rocket 1tb nvme
New build,
Case: Montech 903 AIR MAX
mobo: Asus TUF GAMING B550-PLUS WIFI II ATX AM4
CPU: AMD Ryzen 7 5700x3D
RAM: 2 x 16 gb 3200 cl16 ram (corsair vengeance lpx ddr4)
PSU: Corsair RM750X
GPU: UNDECIDED
COOLER: Thermalright Peerless Assassin 120 grey
Storage: Samsung 990 pro 1tb with Samsung 980 Pro 2tb as secondary storage
This PC is for tasking/working and gaming, mostly gaming. I play different games and it often changes. I have been playing Destiny 2, xdefiant (game finishing soon), warzone and days most recently.
I currently have a 1080p monitor and would plan on moving to 2k/1440p monitor soon at some point this year and then eventually move to 4k in the future. So for a bit of time, it will be 1080p and then the majority will be 1440p.
The budget is 300gpb max for the GPU. I first was thinking either AMd Radeon rx 6700 xt or rx 6750 xt which I can get new for around 300 and comes with 3 years warranty. However I can get a Sapphire Nitro + AMD Radeon RX 6800 XT for 320. But this is secondhand and wouldn't come with any warranty etc. I liked the sound of the RX 6800 XT as it seems a lot more powerful, can run some/most 4k games on decent settings so would future proof me fore longer, but it is a 4 year old card and would have no warranty if something went wrong.
What would you guys recommend; a new rx 6700 xt or rx 6750 xt? or a secondhand rx 6800 xt?
Or if there are other GPUs for that budget you would recommend new and used that I haven't mentioned, what would they be?
Thanks
Old build,
PSU: CX450M
GPU: GTX 1060 6GB
New build,
PSU: Corsair RM750X
GPU: UNDECIDED
Thanks
