I have the EVGA 570 Superclocked Graphics card which, as the name suggests, comes pre-clocked (Core 797MHz, Shader 1594MHz) but it's running a little hot. When playing games like Dead Island or the BF3 beta the temps are in the mid to high 80's. I use MSI Afterburner to make sure the fans actually kick in and this keeps the temperatures to high 70's or occasionally 80/81 (especially this weekend with the stupid weather we're having in the UK). I think this is ok but the fans make a lot of noise.
I've looked in to some after market coolers and there seem to be a few options which will help with the heat and the noise but the problem is that I (foolishly) bought the Micro version of the Asus P8P67 Pro motherboard. I only have the Graphics Card and an Asus DX2 sound card fitted but already it's lacking space. If I fit a different cooler to the graphics card it will only leave a centimetre or two between that and the sound card as, from what I've seen, it will become a 3 slot card.
So, my questions are:
1. Is 80+ too hot for the GPU or am I worrying over nothing?
2. If it is too hot is there any point getting an after market cooler (not water!) since it's likely it would just be blowing straight on to the sound card?
3. If it is worth getting one, any suggestions on the best? And are they relatively easy to fit? I've been building my own PC's for a while so I'm not a hardware novice.
Any advice and guidance would be greatly appreciated.
Thanks
Thanks
