Hey guys
My GPU has been acting all picky for the last while, and I've run out of ideas. As far as I can tell its not contacting the PCI-e slot on the mobo properly, and thats causing games to crash, or flickering lines to appear across the screen, reboots, and general annoyance. It seems to be sagging and pulling itself out the slot just enough to cause problems.
I've tried metal and rubber washers on the screws to try hold it in tighter, a gpu brace thing I had from an old case that I bodged in place, and inserting it really really carefully. Each of these seemed to help for a while, but then it would be back to its old problems once again. I've tried the card in the middle slot for a while and it seemed fine, which led me to think the GPU could have stressed the top slot a bit..
Would a backplate help the card not flex as much and therefore stay in place better? Or could it the top PCI-e slot be acting up?
Any better ideas? Or is it worth RMA'ing the motherboard and going from there?
