Hi,
I currently have a budget of £400-£500 to upgrade my GPU. Currently I am running an entry level MSI GTX 1050ti Gaming X 4G. My PC specs are the following
MSI B450M PRO-VDH
AMD Ryzen 5 2600 OC 4.1GHz @ 1.35v - Liquid Cooled
G.Skill 16GB DDR4 3000
MSI GTX 1050Ti Gaming X 4g
2TB Seagate Barracuda
750W Artic Blue Power Supply
My biggest problem here is i'm limited on space in my tower, the GPU would need to be less than 260mm long. I've been looking at the GTX 1080ti and AMD Radeon RX 5700 XT. I've very quickly found out there is no chance of getting either of these cards to fit as they are both around 300mm long.
After a bit more looking around I've come across a Sapphire Radeon Rx 5700 XT 8GB which measures in at 254x135x46.5mm, its the version with 2 fans and a core clock speed of 1670Mhz & 1925Mhz Boost, slightly lower than some of the larger RX5700s. I'm fairly confident this card would still be a nice upgrade from my 1050ti, i'm just looking for some advise to get the best bang for my buck.
Suggestions welcome
Thanks
Carl
MSI B450M PRO-VDH
Suggestions welcome
Thanks
Carl
