I've just got hold of a Dell Vostro 460 and I'm looking at upgrading the GPU. The Specs are
i5 3.3ghz
8GB RAM
1TB HDD
Radeon HD5450
350 Watt PSU
Windows 10 64 bit
Now my first issue is not having much money to spend, so if I can upgrade to card that works with Win10 without changing the PSU then I'd be very happy.
However, it's more likely the PSU will need to go as well in which case I don't want to spend much more than £150 if I can.
The other issue I'm less sure about is having a PCIE 1.0 slot and whether this will limit the choice of cards.
It will mainly be used for games but I don't expect to be running anything on Ultra settings, just having games like Alien Isolation running at a reasonable from rate will do for me.
Thanks in advance.
i5 3.3ghz
8GB RAM
1TB HDD
Radeon HD5450
350 Watt PSU
Windows 10 64 bit
Thanks in advance.
