GPU upgrade from GTX 750 Ti
8 Jul 2019
Hello, I am looking to upgrade my GTX 750 Ti to something more powerful for my rig, my specs are the following:
CPU - I7 3770 @ 3.40GHZ
RAM - 12GB (8gb+4gb DDR3) @1600MHZ
MOBO- ASUS P8H61-M LE/USB3
GPU - GIGABYTE 750 TI 2GB GDDR5
HDD - 640GB WD6400AAVS
SSD - 120GB KINGSTON A400
OS - WINDOWS 10 PRO 64BIT
I play games such as Overwatch, GTA V, Destiny 2, CSGO, Dead By Daylight, Fortnite etc and would like a new graphics card that will be able to run all of those games on high settings at 60+ fps.
I am not on a tight budget but cheaper the better.
Thanks,
Suppose it depends on your definition of a tight budget. RX570 for about £110 will do the job very well and huge upgrade.
Other cards to look at in order of cost are RX580, GTX1660 or GTX1660Ti.
cheaper the better.
You could try a new GPU first (need your monitor spec - but assume 1080?).
If this were to full-fill your needs for the interim - you could wait for the release of the b550 boards (or b450 MAX ~September) - and get a 3600/3700X build for a very reasonable price, assuming price drops, especially around the time of B550 release.
