GPU upgrade how far to go, CPU dependant?
Permabanned
27 Jan 2006
4400x2 939 @ 2.7ghz.
2GB RAM
X1900XTX @ 688/733
1920x1200 screen, but I might use lower resolution for more intensive games.
I'm looking at a 8800GT overclocked with a S1. A 8800GTS has been recommended for the resolution, but at what point does the CPU hold the GPU back? ie using a 8800GTX SLI with a 1.8ghz single core Athlon is a bit pointless.
At higher resolution and higher details the difference between a fast and a slow CPU becomes smaller. X2 at 2.7Ghz is still a pretty decent chip and should be able to keep up.
Agreed that a GTS or GTX is more suitable for that res.
