GPU upgrade in a Corsair 250D
31 Oct 2012
Hi all,
I'm currently running a GTX970 in my Obsidian 250D. The card according to MSI's website is 277mm long.
Does anyone have any experience or success fitting a 1070 into this case?
Cheers
David
The 1070 HOF cards I think are around 330mm and I'm pretty sure that's the biggest 1070 length wise, I may be wrong!
Thanks for your reply. That would be far too big. I need to have a good measure when I get home but I think I only have 20mm max to play with before the card hits the front of the case.
290mm is the Maximum GPU length according to Corsairs website so a few of the 1070 models will fit no problem, its just a case of finding what one but there are a few that will go in there
