GPU Upgrade & More
4 Nov 2024
England
Hi All,
I have recently installed the recent Black Ops, and came to conclusion that my 2070 Super may not be cutting it anymore, I am looking to upgrade and was wondering if I could get any help on doing so, I will list my current specs below, I would appreciate if, if you think something else may need upgrading also, let me know as I am open to looking into getting it done.
Current Specs:
CPU - AMD Ryyzen 7 3700X 8-Core Processor
RAM - Kingston Fury Beast 32GB 3600 MHz
GPU - NVIDIA GeForce RTX 2070 Super
MB - MSI B450-A PRO
Thank you in advance,
In addition to the above -
PC case - Zalman Z7 Neo Midi-Tower Case
PS - Corsair CX-M Series 650W 80 Plus Bronze Semi Modular Power Supply (CP-9020103-UK)
What resolution are you playing the game at?
What is your budget?
You can have a look here to get an idea how each card performs:
Best bang for buck right now is definitely the 7800xt if your budget allows.
Can be had for around £380 new with a discount codes and a bit of luck (might get a couple games with it for free too).
You won't get full use out of it if you're not playing at 4k with your current CPU, but you should be able to get like 90% of the performance from it depending on the game.
Hi All,
Current Specs:
MB - MSI B450-A PRO
What's your budget? can't give a suggestion without that.
That is an incredible price. I paid £515 at launch. Ouch.
