Hi there,
I have had a huge amount of help over the years from these forums but never needed to actually post before.
Before I explain exactly what I am after, I realise I am aiming for something that may well be unachievable.
I am looking to upgrade the graphics card in an HTPC setup that I built several years ago. These are the existing system specs.
Motherboard: Asus P6X58D-E
Intel Core i7-930
12GB Kingston 1600MHz DDR3
120GB Vertex 3 SSD
WD Caviar Green 3TB HDD
1TB 5400 HDD
Seasonic X-400FL Fanless PSU
HD 5750 1GB GDDR5 Silent Graphics Card
WinTV Nova-TD 500 TV Tuner
The weak link in this system is clearly the graphics card, which I went for due to the fanless design.
I've been incredibly happy with the system, but I am looking to update the graphics card for several reasons.
Firstly, I am PC gaming more and more (damn you Assetto Corsa), secondly I am thinking about buying a 4k TV, and lastly I want something that is going to be future proof for when the Oculus Rift arrives.
I am looking to buy something that is as powerful as possible, as quiet as possible, and falls below the limits of my 400W PSU that is already running quite a bit of kit.
Complicating matters further is the fact that the case is a Silverstone LC-16M which due to the ridiculous position of the optical drive means I am going to try losing the BD drive, or swapping to a Silverstone GD-08.
So - how do I achieve the impossible, high powered quiet gaming card capable of supporting the Rift, 4k, on my limited power supply and space??
The easiest option is to go for a fanless Geforce GTX 750 Ti. This won't stretch me on space, or power, but is only a modest upgrade from my current card.
If I didn't have the other limitations I think I'd buy a Gigabyte GeForce GTX 970 in a heartbeat, as it obviously has the power, is allegedly very quiet. Unfortunately that would necessitate a case upgrade, and I'm not sure the PSU would be able to handle it. I'd probably be prepared to upgrade the case and card at once, but case, card and PSU seems a lot to spend just for essentially a GPU update to a computer that is currently working well.
Additionally, there is only one fanless PSU that supplies >500W, and I'm not sure how I feel about a PSU that strong without any active cooling.
I realise that's a lot of info, but I really would appreciate some people's opinions on what they feel would be a good upgrade route - go for the cheaper card for a slight improvement, or go the whole hog and upgrade everything because the improvements will be worth it, or some compromise of the two??
Greatly appreciated in advance.
Intel Core i7-930
120GB Vertex 3 SSD
1TB 5400 HDD
