GPU Upgrade Question
18 Oct 2002
Aberdeen
Ive had a look around at some Benchmarks and I think I know the answer to my question but ill ask anyway
is it worth upgrading to a 7900GRE or Nvidia 4070super from a 6800 non xt, I game at 1440p.
Do I just wait for next Gen, the only thing I was thinking of was Frame Gen ie Dlss or AMFM not sure its worth it though.
I wouldn't bother, personally. Assuming you get about £300 for your 6800, you're looking at ~£250+ to upgrade. You won't be getting anywhere close to double the performance. I'd just drop a few settings and/or turn on FSR.
You should be able to use FMF on your 6800. It works on my 6900 XT.
Depends on whether you feel like the games you play aren't running as well as you'd like or not. Personally, I don't think an ~30% increase is enough to justify the cost. Also, you can use frame generation on your current card, both via FMF and by modding it into DLSS frame generation games for a better experience.
