GPU Upgrade
30 Aug 2006
Looking at buying a new GPU for around £200-300 to upgrade my old 8800GT. I currently have a C2D E6400 @ 2.6Ghz and 6GB of RAM, I'm thinking about getting a 5850 or a 5870.
Considering my current hardware is over 3 years old will it still be worthwhile to do a GPU upgrade? Or will my new GPU be severely throttled by my ageing processor.
5870 Vapor-X! I was like you didn't know what to get, after looking at benchmarks and ofcourse a lot of help on here I decided to get the 5870 :D. But, it's your choice :cool:
However, i'll let the people who know more about me give you better advice, not sure what type of card will be good for you since your rig is over 3 years old. Should be able to get something decent tho :)
You CPU is certainly a bit slow...have you tried overclocking it?
At the CPU current speed, if you are getting a 5850/5870 the chances are it will not be any faster than a 5770, because your CPU is simply not sending data faster enough over to your GPU for it to really show its strength.
With that said, you could get a 5850 now at £230-£250 now, and then try to save another £350~£360 and then upgrade your platform to i5 750 (CPU+CPU cooler+motherboard+4GB DDR3 RAM).
With your current CPU, a 5770 would be more than enough, however, if you can clock the cpu to 3ghz or more, then a 5850 will do wonders for your frame rates :)
I can get the CPU up to 3.2 Ghz it just runs a little hot (up to about 65 deg C :D), so that's no problem.
My Lian-Li PC-7 case is a little on the small side, how big are the latest ATI cards?
Edit: Also is a Corsair 520W PSU ok for a 5850?
