GPU Upgrade
29 Aug 2012
Hi,
So I've finally decided my GPU needs an upgrade because, well basically it is rubbish. Its a ATI HD4650 1GB.
I'm not brilliant with GPUs so im not sure what is best to go, my budget isn't huge but ive got up to about £150 to spend.
I use my computer pretty much for gaming so i'd like something that wont be useless again in december.
Also after the GPU i will be hopefully getting a better resoloution moniter so it would need a HDMI slot if possible.
Any ideas would be great, my full (and awful) computer specs are in my signature.
Thanks,
B088Y
That one is 1GB vRAM, it will do the job but if you want a bit more future proofing get the 2GB
http://www.overclockers.co.uk/showproduct.php?prodid=GX-100-GI&groupid=701&catid=56&subcat=411
If your planing on keeping the card for a year or more i recommend you do get the 2GB.
Nothing comes close the the 7850 in the £150 mark, that's it :)
