GPU usage show difference!
3 Oct 2013
Can people (AMD and NV users) check to see if they are getting different Gpu usage shown between GPU-z and afterburner please.
Only noticed tonight as messing to see if I could get my usage change with AB on my 290x in bf4. That's when I noticed GPU-z said 60ish % but AB said 98% :confused:
I normally use GPU-z to see VRM temps if am playing
Don't know if its just me or in general, or even caused by the AMD 14.1 driver ;) which wouldn't surprise me :rolleyes:
Afterburner is generally more accurate than GPU-Z. If I alter volts with AfterBurner, I see it in AB but not in GPU-Z.
^^ I'm with Gregster on this. Only AB is showing voltage changes on my HD7950. Even Aida shows no change, but the change defo happens cos temps change.
On usage% they all match tho, so maybe just a glitch for you. Drivers have never made a difference to me.
What's the temps like, that'll tell the truth.
