Hi
i am trying to put this http://www.overclockers.co.uk/showp...rodid=GX-045-OK under water but i am having some problems. when trying to fit http://www.thermaltakeusa.com/produ...38/cl-w0038.asp onto my card it does not seem to fit flush and the gpu overheats, has anyone tried this on the same card before and can you give me any tips on how to do it correctly. There is a black foam square surrounding the gpu, is that the problem? i do not want to take it off of it is not to blame for it
edit: links fixed
edit: links fixed
