GPU Waterblock Compatability
2 Jan 2010
I have 2 HIS 6950 ICE Q which i noticed is NOT reference design, so in respect of waterblocks i dont think the full block will fit.. can anyone confirm or deny this?
this is my card
and a stock ref
If as i suspect it wont, is it worth going for a universial block? With some heatsyncs on RAM?
Might finally get this watercooling worked out soon haha....
The problem is going to be the capacitors you have on your card on the left hand side. If the waterblock doesn't have correct indents to accommodate them you could damage your card.
Well if your card is listed on coolingconfiguratr as incompatible, then it's incompatible
BTW, you can't hotlink images, i'd take them off or rehost them yourself :)
