Gpu WC kit
27 Sep 2005
Cornwall / Helston
Hey all, looking for a complete water cooling kit for a Gigabyte GeForce RTX 2070 WindForce X2 rev3.0, I cant seem to find 1 specific for this card.
Any advice?
Regards
Phill
@evulboo looks no one makes water block for your card at the moment. u could try the g12 + AIO option currently my 2080TI does not hit over 50C when gaming so a 2070 should be a lot lower say 40C
Just checked and seems the the 2070 isn't on the supported list
contact alphacool to see if they have 3D scanned one yet .
will give this a go cheers
Looking at the listing on here, apparently it does support the 2070. Did you use any memory heatsinks or just rely on the 92mm fan?
@evulboo I have just rely on the 92mm fan as the EVGA cards have a Front plate mounted cooling plate. I see from pictures your card does not have this so small heat sinks could be used but I think the 92mm will be fine keeping those components cool
@hlennie Installed the Kraken G12 and kraken 52, had to do some mods to the brackets and drill some new holes, but idle temps are now 25C and max 45C under load with 170MHz added on the clock :) all whilst running silent, needless to say i'm happy!
https://i.~ibb.co~/3NwpNZC/20200428-211728.jpg
https://i.~ibb.co~/HDRpjYJ/20200428-211016.jpg
https://i.~ibb.co~/dm3qczD/20200428-221533.jpg
