Gpu won’t fit.. help needed
17 Feb 2009
Gpu wasn’t going in easy in the end I had to use some more force so that it clipped into the case. Got there in the end but may have more questions further on into the build
Before closing thread is there a good way to test the mobo etc is working in my new case before I go doing all the tedious stuff I.e fans and cable management ??
You'll need CPU, CPU cooler, board and one stick of RAM (plus GPU if you have no IGP) and connect the front panel if there's no power switch on the board, which should boot straight into the BIOS.
Thanks dude may as well keep the thread open in case of any other questions
