Gpu-z Readings questions
25 Nov 2011
The KOP
Guys how accurate is Gpu-z?? I have my Voltage set using msi AB @1.037v but GPU-z is reading 1.498v :eek:
This was from about 1 hour Crysis 2 gameplay on Ultra settings and I also notice my GPU load hit just 91% surely thats wrong? My i5 2500k is OC to 4.5Ghz.
So my question is should I trust Msi AB for Volts or GPu-z?
I have had a few spurious readings of my VDDC with GPU-Z . 1.185v set & the the reading was 1.38v max , i don't take any notice of it as the temps did not raise above their normal level.
