GPU-Z v2.11.0 Released
19 Dec 2003
Grimsby, UK
AMD 7nm Vega 20 GPUs can't be that far away if GPU-Z have done an update. :)
GPU-Z v2.11.0 (September 17th, 2018)
https://www.techpowerup.com/download/techpowerup-gpu-z/
Release notes:
  • Added NVIDIA GeForce RTX Turing support
  • Added option to minimize GPU-Z on close
  • Added system RAM memory usage sensor
  • Added temperature monitoring offset for Threadripper 2nd gen
  • Fixed typo in NVIDIA Perf Cap Reason tooltip
  • GPU-Z will no longer use AMD ADL memory sensors because they are buggy, WDDM monitoring used again
  • GPU Lookup feature improved by taking boost clock into account
  • Added ability to clean up old QueryExternal files in temp directory
  • Added support to BIOS parser for USB-C output, GDDR6 memory, 16 Gbit memory chips
  • Added support for NVIDIA RTX 2080 Ti, RTX 2080, RTX 2070, GTX 750 Ti (GM107-A), GTX 1050 Ti Mobile 4 GB, Quadro P1000, Tesla P100 DGXS, GeForce 9200
  • Added support for AMD Vega 20, Fenghuang, Ryzen 5 Pro 2500U, 5 Pro 2400G, 3 Pro 2200G, 3 Pro 2300U, 3 2200GE, Athlon 200GE, Embedded V1807B
  • Added support for Intel UHD 610, UHD P630 (Xeon), Coffee Lake GT3e (i5-8259U)
Release notes:
Yay a version that actually supports KabyLake-G :)
