Hello, if you have a with a watt meter and are a little boared could you do a little test for me plz.
I would just like to know how accurate the amp reading in GPU-z is, according to GPU-z my gpu is drawing 30 amps at .88v running at 600mhz, and 125 amps at 1.288v running at 1200mhz.
So basically could someone just run a similar test but recording the watts on their meter each time.
The reason im asking is because if i run 2 cards at 600 mhz, i get 15% more FPS than running one card at 1200 mhz, so if its really saving over 100 watts then ill stop disabling one card when im playing less intensive games and just drop the speed of the cards.
Cheers if anyone can be bothered.
