GPUTweak is already running
26 Oct 2013
Leicester
Well, as you can see, I'm having problems with Asus GPU Tweak. I set it to run but hide itself when Windows launches, but now I can't open GPU Tweak up - it's not in the tray or extended tray, and when I try to open from start menu/desktop, it says "GPU Tweak is already running." I tried to reinstall to fix the problem, but it cannot be uninstalled while it is open. Any help anyone?
Thanks
Can't, says I don't have permissions to do so even though I'm an administrator :/
Okay got it running by changing the boot service thingy, all fixed now - thanks!
Well it turns out gpu tweak has completely screwed over my windows - having to do a fresh reinstall right now. Couldn't log in without getting a black screen with only gpu tweak loafing up, then couldn't get past the windows loading screen without a blue screen. GG, won't be installing that now
Can anyone think of a reason this could happen? Only thing I can think of is that the Intel hd drivers are conflicting with the nvidia drivers
