grabbing multiple screenshots?
18 Oct 2002
Behind you... Naked!
I am doing a load of training, and I am trying to grab the screenshots, the snag is, that I am grabbing it to the Clipboard and so I am only really able to do one at a time.
Is there an app that I can setup PRE-TRAINING and then Everytime I want to grabn a screen, I can simply press a key combo ( preferably Print Screen LOL ) and it saves it to a folder and then I go into that folder and I have a load of pics already there named TRAINING-001.JPG TRAINING-002.JOG and so on?
The training is online and its at a set speed - I am freely able to grab any and all screens, but its a chore to do that, and they do not provide us with a PDF of the courses, so its a bit of a swine if I am honest.
OneDrive?
Oh, ok, I will have a look. I have disabled it on my PC cos I dont want the thing, but if taht will do what I want it to, then...
Thanks bud.
Doesn't pressing prtscrn +windows key
Automatically save them to my pictures/screenshots
Though it wouldn't name them training 1,2,3 etc
But still allows capturing multiple shots that are saved in one place
Immediately
I use ashampoo snap for my screenshots
They're pretty good for giving free version of their software
Once a new version is released
Press Windows+V, enable the advanced clipboard. Now you can save twenty items to the clipboard. Use windows V to paste and you’ll get a list.
In the past I've used the built-in app Step Recorder for taking multiple screenshots. Just remember to increase the max number of captures from the default 25. All captures are saved in a single file.
When you say training is online, is it browser based? Firefox has a built in screenshot button you can enable by adding button to toolbar.
Irfanview has a capture mode that let's you specify an interval and all sorts of other options, like which window and so on.
There are a whole load of programs which can do desktop capture - IIRC even MSI Afterburner you can set it up to do it, definitely does it for video not sure on screenshot.
Windows Key + Printscreen is the native way to do it in Windows, it will screenshot and export/save to Pictures > Screenshots as PNG images.
