So, I realised what a fool i've been the other day, and why it was taking 1.4V to get over 4Ghz.. seems it's a good idea to gradually build up the overclock.
I'm just wondering what the best way to go about this is?
Is it best to undervolt the cpu as far as possible at stock speeds first and let it run for a bit? Or do you find the highest clock you can get at stock voltage and then move on from there?
I've tested it and im able to run at 1.15V at stock speeds, and at 1 notch over stock voltage im able to run at 3.8Ghz. I'm currently running prime95 on it for a good 16 or so hours (72 degrees max temp)
What's the best way to move forward from here? Do you have to stress test it to get the chip used to the voltages you're putting it under or just have it running normally for a while?
