Grammar question
7 Sep 2008
hi what is the difference between
London’s finest
Vs
Londons finest
What would be the correct term for which scenario? Thanks
London's finest is possessive, so something belonging to London, i.e. London's finest whisky.
Londons finest literally means nothing to me. It's plural London, which doesn't make any sense.
I think the apostrophe has a few uses, obviously separating two words such are they're it also gives significance to important names, London('s) being one for example.
still confused......
so the first one means like London's finest gangster...
or London's finest wine
I got that bit but still not sure about 2nd one.
if I was putting this on to a t shirt which term is correct?!
Even in that case you should indicate the possessive - either as "Londons' finest" or "Londons's finest" (there isn't a rule on which style to use but the double 's' looks awkward to me). "The finest of the Londons" dodges it.
If Londons was a brand name you could use Londons Finest as a product name.
Even then there’s an argument to use Londons’ Finest.
That’s the only thing I can think of where option 2 would make sense.
