Been having a wee look at these recently as an HTPC solution and was wondering if anyone here has one?
Only reason I ask is the case is 43cm wide and the space I have to fit it into is 45cm wide - it'll fit but only just.
1 cm either side or 2cm on the PSU side be enough breathing room for it?
PSU will probably be a Corsiar 620W and likely running a C2Q paired with a 7800GT w/ Zalman HS @ 5V
Any ideas would be good
