Grandparent linux!
  • Thread starter Thread starter JC
  • Start date Start date
JC
JC
10 Dec 2003
Surrey
Dare I admit I've rather clueless when it comes to linux, beyond installing a ubuntu liveCD I have no experience but I am aware that it might be what I'm looking for.
I'd like to find a simpler operating system for my grandparents laptop, currently an Acer running Windows XP, firstly is this choice of hardware going to be a problem?
These are the features I'm looking for:
Very simple interface but still appear "pretty"
The ability to use large fonts and icons
Ability to work with dial-up internet
Would be great if it can work with these or similar applications:
Openoffice
Firefox
Thunderbird
Rainlendar
VLC
AV/Firewall if required
Slightly more complicated features that would be useful but not mandatory:
Remote desktop functionality so I can fix things from afar
Compatibility with something that will take a drive image so I can backup to a restore in case they get malicious software on the machine.
Not much to ask eh!
If anyone can suggest which linux distro they'd use or recommend in my position and any known sofware that would help I'd be very grateful.
Cheers
I wouldn't say that Linux is necessarily simpler than any other OS... it does some things differently, and some things better in my opinion, than Windows does them, but I wouldn't go so far as to say it's simpler. However, it's not any more difficult than other OSes to use either ;)
As for the hardware question... dunno - what hardware does the laptop run? Generally, the less bleeding-edge hardware the better your chances are that someone has made drivers if none are officially available from the vendor.
I would suggest any of the popular distros... however, I'd suggest looking at KDE rather than Gnome or xfce, etc... In case you're not familiar with these things, KDE (and Gnome) is a desktop environment. Whereas in Windows, you've got the choice of using the bog standard Windows desktop environment or er... not using Windows, in Linux the desktop environment is separate from the kernel and you are free (and encouraged) to use whatever you feel more comfortable using.
I personally find KDE more "eye candy"-ish than Gnome. Gnome is still a good desktop environment, but I find it's more concentrated on being functional than flashy. You'll be surprised at just how much control you have over how you can make KDE look and feel... it's very refreshing :)
As such, I'd recommend they use the Kubuntu distribution/distro. It's the KDE version of Ubuntu... which ships with Gnome normally (you could just install KDE on a normal Ubuntu, but going with Kubuntu from the start will save you a bit of time and work). I think you'll find the whole Ubuntu (including Kubuntu, Xubuntu (which uses xfce), Edubuntu (an educational-specific distro), etc...) community the best - especially if you're not too familiar with Linux yourself just yet. With the community as large as it is, you're almost guaranteed to find that someone has already encountered any problem you may run into, and will have explained how to resolve it. Check out the http://www.ubuntuforums.org website to see how huge the community is.
Openoffice
Firefox
Thunderbird
Rainlendar
VLC
All of these programs will run fine under Kubuntu... with the possible exception of Rainlendar - which I had to Google to see what it is ;) There will be an equivalent for Linux though.
The need for AV and a firewall is different under Linux... you can get by surfing the internet without either of them and not be worried. However, there are products available, e.g. ClamAV and Shorewall.
Remote desktop functionality... yep, built-in. Several different ways of doing this too. FreeNX, VNC, etc...
Backing up the machine in case of malicious software...? It's easily do-able in Linux. However, if you back-up your grandparent's so-called Home directory, you've pretty much covered yourself. You could back that up to a floppy disk or even email it to yourself. No need to back-up the entire drive.
Thinking about this, there are a few different ways you might want to consider doing this (some are slightly more advanced than others but offer more functionality. For example, you could put your home on a different partition during the installation... takes 30 seconds to do but means you can re-install the entire OS and it'll still appear the same for your grandparents - just as if nothing had happened at all.
Saying that, you'll not really need to re-image a drive because of malware... this isn't Windows :p;):)
Not much to ask eh!
Cheers
Not much at all. As shown, Linux can handle all this and so much more... and it won't cost you a penny to try it out.
Give Kubuntu a whirl. Have a play with the LiveCD or use Wubi if you're a bit more adventurous. I'm sure you'll see how it could be ideal for your grandparents' needs.
Thanks for taking the time to write all that, I'm going to play around with Kubuntu in a virtual environment in my machine and see if I can get my head around it all.
I second KDE, mainly because of personal preference, but it's easier to use IMO. I'd say try Mandriva, one of the things that initially drew me to it was the Mandriva control centre (mcc) has all the GUI programs you need to configure the machine. I don't really like the software installer on Mandriva (add/remove software tab, gui interface to urpmi), which has improved and de-proved over the years, but it works ok.
How about something intended for tiny screens? The version of Xandros on the EEE PC would be pretty neat with its big, easy to use buttons.
Ubuntu Netbook Remix would be cool too. Shame it's not ready yet.
Bingo :)
Mandriva is what you're after in this situation. Yes, it's a little bloated, but IMHO it's one of the most idiot proof distros out there. The control center is also second to none.
-Leezer-
Good suggestion, Jim_Bob. I'd forgotten about Mandriva but it is indeed a good distro when starting out. It's what I used first of all, along with Knoppix. And like *buntu, it's got a nice and friendly community.
Google have released Google Gadgets for Linux, so just about any Google Desktop app/applet will be available too. (i.e. a replacement for rainlendar)
I'd recommend Kubuntu for the least fuss.
There is XRDP which is a primitive RDP Server for *nix, but it's quite buggy and not really much cop if not used with the default X window manager, so I'd recommend going for VNC over SSH.
