Granite Pestle and Mortar or something else/electric?
27 Dec 2009
My main method of reducing ingredients to tiny bits/paste is to chop them up with a chef knife and if necessary stick them in the food processor. However, this doesn't really work for small quantities e.g. if I want to make a bit of fresh garlic and ginger paste or some curry paste to marinade a piece of chicken.
For some reason I don't seem to have ever owned or used a pestle and mortar. Is the solution and if so my Google results suggest that granite ones are the best. Is this the way?
Or should I be looking at some sort of small spice grinder or blender?
A big one sounds like it will fill the need, but will it make my wrist get tired?
Theres something satisfying about having a big one and it certainly gets the job done quickly when your really pounding it, but can be a bit of a strain on the wrist so case try changing hands half way through.
Its also worth putting a tea towel under the mortar so you don't scratch your work surface when your going to town :)
I often find it’s worth putting a towel down when you’re really pounding away with a big one.
If it's a small quantity of just 2/3 garlic cloves say, I grate that directly into the hot pan(or marinade dish) and use finger to wipe & clean remains off grater ..
if you were using a pestle, you'd be wasting it on the pestle&mortar which you can't clean out to the same degree, same for ginger
After 2 weeks it will sit at back the door unused, and it's a great place for keeping your backdoor keys, shed garage etc :)
I used to sell a crazy amount of these to Bangladeshi families:
So many I remember the model number. The little grinder mill - they seemed to be peak for grinding spices for curry pastes etc.
I don't know what model replaced it, but that's my shout for pastes.
Granite pestle and mortars are too much work for pastes.
I've gone the opposite way and now use a Ninja hand blitzer for everything, including curry bases.
See Stein a while ago mention that no Indian kitchen would be without its electric spice blender.
