graphic card drivers keep crashing
20 Apr 2008
Nr Liverpool, Uk
Hi,
I have 2 x gtx 670 ftw 4gb , today when i play games the graphic card drivers keep crashing.
i have tried updating my drivers and also rolling back to older drivers to no avail.
i am cleaning out old driver before installing new ones too.
i have used gpu-z to monitor the card but cant see anything that jumps out at me to be a problem
here is the log just before the crash
Hi,
https://www.mediafire.com/convkey/38ab/2fh9lb4m8m0y9q86g.jpg][/QUOTE]
I've got a 660 and mine keeps freezing up, occasionally bsod. Bsod report says the cause is the graphics driver, I done the same as you, reinstalling all the drivers but done nothing. Temperature hit 76 degrees before crashing, always within a couple of minutes of getting into a game. I'm at my wits end with mine too and think it's could be the card itself rather than software
I have a 780 and i have tried everything on the internet to solve it, mine only crashes when i am on the net, its very weird ive tried to under clock it changed psu,
when i gaming no problem go on facebook and it crashes ill just buy a new gpu when there released
if i was you try underclocking it -100mhz
or give them more volts
good luck
I would use Display driver uninstaller and test with one card, then the other. Do a loop with Heaven 4 and a run of Firestrike then try the other card, then both
Have you tried each card on its own ? One may be having issues.
You never stated what OS you are on and what you used to clean out the drivers .
Try Display Driver Uninstaller (DDU) V15.7.5.5
http://www.wagnardmobile.com/forums/viewtopic.php?f=5&t=245
Thanks for the replys all given me something to try
I used Display Driver Uninstaller (DDU) V15.7.5.5 to uninstall in safemode before clean reinstall of the drivers,
I will try 1 card at a time as suggested , it is really annoying when things go wrong :mad:
Have you used 364.xx driver? if you did, then roll back to/install 362.00 driver. Hilarious amount of users have the same problem. Nvidia , dead silent about this matter. Just read one of the post somewhere else , the guy changed hes 580 3gb vram(but why?) to 760 and ended up with black screen and crash. Now he needs to buy a new vga.
Funny that , i did a system restore to about a week back and installed drivers 361.43 problem has now gone away..... its strange as i did a driver wipe pre this and problem still persisted.
latest drivers are rubbish as usual !!!
