- 4 Oct 2004
- Yorkshire
Hi,
I currently have a Shuttle XPC SB83G5 running as a media PC hooked up to my LCD tv via the integrated gfx card using a standard D-Sub link. I was planning to use a surplus Sapphire X850XT gfx card (double width)so that I could use a DVI-HDMI cable. Unfortunately the PCI-E slot in the shuttle is single width!!! My options are:
1) Modify the X850XT with a thirdparty fan-heatsink to be single width (any recommendations?)
2) Buy a single slot gfx card such as the 7600GT by BFG? (good choice?)
Cheers
Paul
Cheers
Paul
