Hey folks , need a little help here .
A few weeks ago I started having problems with the PC , it's 3 year old and originally bought from here , been a good little PC up till now .
I had a few graphics card problems , game freezes / black screen , then everything runs normal . Along with one or 2 hard drive failures at the same time .
I took the PC to be repaired when in one night I had around 6 of these crashes along with a few bluescreens and a hard drive failure .
The PC repair place phoned me to say the hard drive definitely needs replacing and the graphics card is fine , after running whatever tests they do .
Okay finally get the PC back and the graphics card is still constantly freezing/black screen then running okay . I do get the display driver stopped working pop up . This only happens when gaming , I have never had one on the desktop . All I am playing at the minute is WoW . I used to play with all settings on Ultra but have gradually dropped them to around medium with same results . I did have Diablo 3 on the comp and believe the last time I played it it also had screen freezes . This can happen after 2 minutes playing / 30 mins / 3 hours , pretty intermittent .
I did ring the shop but got told they ran the tests and found nothing , they can't test for every eventuality . Which I suppose is fair enough .
The machine is running very cool , so temps seem fine . Drivers are up to date so I'm at a loss .
I am not techie minded so please bear this in mind , cheers .
The card is an amd Radeon 5850 , so getting on a bit , if it just needs replacing that's great . I just don't want to replace then find my new card does the same thing . I'm not that rich to replace things willy nilly . I do have £160 put to one side just in case , I was looking at the Sapphire HD 7850 that was on sale here last week . Actually just saw this http://www.overclockers.co.uk/showproduct.php?prodid=GX-100-GI&groupid=701&catid=56&subcat=411 what does the 2x mean , is that the number of fans ?
So folks , any help would be greatly appreciated before I stick my order in
Thanks
Just an aside , today is the worst ever , around a dozen times now in under an hour , had 5 in 2 minutes , getting consecutive freezes one after the other now .
Thanks
